I have a Touareg that turns off parking sensors when our trailers are attached.
I used the D4 2012 to tow both of these in the last few days, but yet the parking sensors still work (trailer lights are led on both trailers and work fine). Found I could turn down the annoying noise with the radio volume controls.
Is this normal ? If so....the LR technicians buggered that one up.
 Swaggie
						Swaggie
Here is one solution.
www
I have mine fitted to the D4 so I can tow other trailers with LED's
Same as Mowog! The little box works a treat.
In my D4 its in the left hand rear compartment. This the side where the tow hitch is stored. The switch to turn it on an off is mounted in the trim just above it.
I have a Kaymar rear bar and having it fitted to the D4 it turns off the parking sensors if it is turned on.
Ditto the Linear electronic design unit, have mine mounted in the tow hitch space also. Great piece of kit.
Cheerls
I have a special box on each trailer to make the LEDs work for my touareg.Originally Posted by Graeme
I would have thought that would have been enough...I guess not.
I actually have that fitted to each trailer. LEDs work perfectly on both cars, just parking sensors don't turn off on the disco.Originally Posted by mowog
 Wizard
						Subscriber
						Wizard
						SubscriberAnd the car does more than just turn off the sensors if it thinks there's a trailer there, so its possibly not altering the gear changes, activating trailer stability etc either?Originally Posted by discotwinturbo
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
