I haven't looked, but can any of those smartphone OBD programs read boost?Originally Posted by discotwinturbo
Had a look through the search function for scan gauge and analogue gauges for the D4.
It seems that the scan gauge does not show boost and EGT ?, so need to look for an analogue gauge. I like the Autron analogue appearance (which is apparently digital but looks like an analogue gauge). It has both all in one.
Has anyone mounted analogue gauges in their D4....if so any pics would be super.
The only spot I found was the blank to the left of the instrument cluster. I can view this inside the steering wheel.
Any ideas or thoughts would be appreciated.
 Wizard
						Subscriber
						Wizard
						SubscriberI haven't looked, but can any of those smartphone OBD programs read boost?Originally Posted by discotwinturbo
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
yes, iv had it working
 Wizard
						Subscriber
						Wizard
						SubscriberHave you seen these.
ThermoGuard Instruments
DREW
Not sure they will work as you want them to but worth a look
Gary
Stig......what app did you use ? Do you use android or iPhone ?Originally Posted by stig0000
Did both boost and egt work on these, and what other functions worked ?
I have contacted a couple but none could confirm what functions would work on the D4.
Thanks for the reply.
Thanks Gary.Originally Posted by 33chinacars
I have sent these guys an email.
 Master
						Subscriber
						Master
						SubscriberI use Torque app on android phone and scantool bluetooth OBD reader. I know it shows turbo boost. Not sure about EDG. This setup shows lots of other info as well. It can cause Canbus errors as you need to set the obd reader protocol to match the protocol used in the disco4.
I had one (Autron) in my D3 -see my gallery (haven't fitted one to my D4 yet).
i use tourqe pro,, its good for a qwick check and clear of engine codes,, and road test with for live date as it can allso record,
it shows 80% of the things you can see on SDD, its a good cheap tool
Stornaway .... I think you have won me over. I will check with rovertech to make sure they can fit this for me, then I will place the order. Apparently the light colour can be changed, so will be able to match it as close as possible like the scan gauge.Originally Posted by Stornoway SA
