Results 1 to 10 of 16
Thread: Internal Bead Locks
    Mar 2009
    Internal Bead Locks
    Hi All.
    Has anyone tried internal bead locks? Expensive waste of time or great idea? The idea looks great to me but would like opinions from any users or other. Thanks Tony.
    98 Defender 110 tdi Boomer
    Yinnar South, Vic
    I had them....now I don't
    I reckon a heavy duty tube is better, Internal beadlocks still get crap in the beads and you still have to break the bead to clean them
    Mar 2010
    victoria
    i've had internals for a few years now. when i first got them i had problems with them losing pressure ie: both the tyre and beadlock pressure would equalize but that was due to a the installer (well known company) not installing according to the instructions. after getting them installed correctly they've been fine.
    Quote Originally Posted by rovercare View Post
    i've had tyres as low as 7psi in muddy water for hours and no problems with crap in the bead. what tyres did you have and what pressure did you run the beadlocks? i used to have swampers but currently have bfg muddies. i keep the beadlocks at min 40psi.
    Yinnar South, Vic
    Quote Originally Posted by BreakingBad View Post
    Simex centipedes, 35x10.5x16 on 8", 40 psi internals, 14-16 in the tyres, aggressive driving in the ruts would always see me with a leaky bead, I'm not the only one by far, I had less trouble with Simex tubes fitted, I never lost a bead with them, just niggly leaks
    Mar 2010
    victoria
    do you know where the niggly leak comes from?
    maybe it's the brand of beadlock? i've got secondair.
    Yinnar South, Vic
    Crud forced into the bead, it's the nasty driving in ruts that does it, they were second air also, that's why nobody in racing runs them, years ago there were alot with staun and second air headlocks when they were new and in vogue, everyone promptly went back to externals
    If they suit you and your driving that's great, just my experience differed, I never used to be nice to my stuff though
    Had secondairs for a few years now, not a single problem. Never had crud in the bead. I keep min 30 psi in the bag.
    While I've given up on Simexes, they were fitted to stop the damn things from peeling off the rim. Constant Simex problem. The secondairs fixed that once & for all.
    Max P
    Mar 2010
    victoria
    on a few occasions many many years ago i had 235/85 bfg's on boost alloys without beadlocks and i got crap in the beads after aggressive driving in ruts and sliding down into ruts. on both occasions it was a rear tyre and i hadn't lowered tyre pressures so they were >=40psi (i was new to 4WDing)
    If you use tubes and you get stuff in the bead the stuff will work its way into the wheel and rub on the tube until it wears a hole in the tube. is that the niggly leak you are referring to?
    Anyway, from my experiences and what you've said i'm thinking that the forces applied to tyres by aggressive driving in ruts might be the major factor and if the force is great enough the bead will get stuff in it no matter what. having said that it seems logical that using tubes for this type of driving will give you more time before the tyre goes flat?
    North Central Victoria
    Aren't internal beadlocks illegal in all states of Australia on road going cars? (He says with a heavily modified D2 with 235/85 tyres and no muffler and no engineering cert)
    Mar 2010
    victoria
    Quote Originally Posted by gusthedog View Post
    i asked Vic Roads in 2007. this is the email i got back.
    "There are two types of beadlocks recently seen on 4 x 4s.
    Mechanical devices
    These are bolted on and are definitely not allowed as they compromise the wheel and have a history of causing wheel failures. They appear to be extremely difficult to obtain acceptable balance and when they fail the outer portion seperates and becomes a hazard to other road users as well as causing a loss of control of the vehicle..
    The inner tyre type
    These are basically a specialisd reinforced tube that uses air pressure to hold the tyre bead against the rim. An extra hole is drilled into the rim to allow the extra tyre valve to be accessed. This type has been used for some time and no known failures have been reported. Providing that the hole is drilled and finished to an acceptable standard consistent the original, there should be no problem. However as with any work done it should be checked regularly for crack propogation or distortion as the vehicle operation that beadlocking allows may be harsher than the vehicle manufacturer allowed for in their component design."
    Can't comment on other states.
