The taller of the Pair goes on the drivers side....Ok set some time aside to do my springs and shocks a couple of silly questions,
King springs are marked right and left. Is the right hand side the drivers side?
Works really well actually, greatly reduces the road noise.Also have some spring isolators ANR2938 these are off Disco's but read you can use them on Defenders (Mines a 2001 110 TD5). anyone had any problems using these.
Yes if doing springs & shocks - No if only doing springs.Finally do you need to remove the (black) cover from the guard to replace the shocks and tower?
Your very welcomeTHANKS IN ADVANCE![]()
