To gain access to the rear of the centre cubby box, you will need to remove it.
To do this you will need to ...
Open cubby box lid to 180 degrees, T40 or T50 torx bit & undo the bolts at the sides of the lid, remove bolts. Then remove silver caps by lifting upwards.
Lift lid to vertical & slide lid upwards & off.
Remove drink holder from front of cubby box, remove panel in front of cubby box under handle. You should see 2 T20 torx screws, remove these & the entire inner cubby box will lift upwards & out, a little force is required.
This should give you access to the plug.
The wiring loom also runs down the side to the rear of the cubby box.
HTH
