28th December 2011, 11:59 AM
Engine belt idler removal
Hi
Quick question how does a engine belt pensioner pulley come off ? same as the aircon one -i am looking to replace the the bearing.it is a tdi 300
28th December 2011, 02:14 PM
15mm socket on the center bolt undo to the left then remove.
28th December 2011, 03:00 PM
Thanks is that the actual pulley or the whole tensioner?
31st December 2011, 12:49 PM
#4
The defender is still in the shed does the pulley come off the tension-er ,and can i put a bearing in it -i9m pretty sure it does but it seems pretty tight id hate to break it during this preriod of global close down over xmas
31st December 2011, 04:26 PM
#5
Yes the pulley does come off the tensioner. It is a left hand thread bolt, so move the bolt clockwise to undo it. The bearing can be replaced, it is a 6203 bearing from memory.
1st January 2012, 10:00 AM
#6
Thanks woko and ade ill get onto it when it dtops below 42degrees(prob 50 in the shed
