Results 1 to 10 of 34
Thread: Internet options
    Bracken Ridge, Qld
    Internet options
    I’ll be moving to a new place mid January and will need to organise me some interwebs.
    I am unsure at this time whether there is any Telstra or Optus cable connected.
    I went to the Telstra store yesterday and was unimpressed. The salespeople seemed to just refer to their intranet mirror of the Telstra website for all their info. I could have done that from anywhere myself.. The array of options was bewildering, the lack of logic in the way they are priced astounding (how can a package be cheaper than internet alone?) but they were all pretty expensive.
    So perhaps people can tell me what options there are for internet connection, what companies are good, and what the “going rate” is?
    I’m out of touch coz I’ve had Optus cable at my old house for as long as I can remember.
    I have no idea how many Gb / month I’d need and can’t seem to get a report from optus as to how much I’ve been sing at home historically. I tend to do a bit of internet gaming, watch a bit of youtube (and upload the occasional 1 Gb video) but aside from that not much data intensive stuff just forum browsing and so on.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    If you have had the luxury of cable, you are not prepared for the situation you will face away from cable. Before you can consider plans, you need to find out what infrastructure you have. This is neither simple nor easy!
    With luck, you can get ADSL2+, but there is no mechanism to tell you in advance whether it is actually available (in some cases you can find out it is definitely not!).
    Failing this you are likely to have either wireless (expensive and a a bit shaky in most cases) or satellite (slow, expensive and high latency, but NBN interim service is now taking orders for almost immediate installation).
    It is probably a good idea spending a bit of time browsing http://forums.whirlpool.net.au/. Other things apart they have lists of plans, but also look at the problems others have had.
    Jul 2011
    Yarrawonga, Vic
    Go to this website
    http://bc.whirlpool.net.au/
    and type in your new phone number
    or a phone number of someone / business etc near where you are moving
    plus how much you want to pay etc etc and it will give you a list of choices.
    May 2002
    Heathcote (in "The Shire")
    Go to this website
    Not very accurate though,
    Tried it for my place, as far as it's concerned I can get Optus Cable. bzzzzt wrong answer Tony
    Martyn
    Adelaide SA
    Ok, at the risk of getting shot down in flames, I would go with Telstra...
    I have cable, 50gb per month.
    It is very rare that I have any sort of issues, and on the times that I have, it has been fixed quickly.
    Why you are at it, I would never recommend VOiP for a home phone. Why? If the power goes off, you have no phone. Yes, I know you have a mobile (probably), but if the service is dodgy, battery is flat, you left it in the car, drop it in a mad scramble....
    I know personally of some people that had a fire in their range hood. As expected, the electrical safety switch tripped, so no phone. She dropped her mobile ejecting the battery... finally called the firey's on his mobile.
    I will, for as long as possible, have a fixed land-line phone - not just a cordless.
    Perth West Aust
    I agree with Basil.
    Telstra always with me, as it just simply always works and when there is a problem they are quick to fix it.
    I just got ADSL connected last week and needed a line connected as well for the ADSL to work from. 50GB a month plus line rental is $72.00 per month. Call Bigpond connections direct, for a better deal, dont go to a Telstra shop.
    To cut a long story short, went to connect Modem on Xmas Eve, found out I had no dial tone on newly installed line (connected at exchange) rang Telstra faults at 9.00 pm. Line was tested faulty, with a request for Tech to come have a look. With the Xmas break, line was repaired Thur 29th as guaranteed.
    I looked on the Net and could have got cheaper deals, but I doubt if I would have had the connection problem fixed so quick and easy, particularly this time of year.
    Greg
    Crafers West South Australia
    Quote Originally Posted by Basil135 View Post
    I too use Telstra, it works well most of the time and is usually fixed quickly when it goes down. I manage easily with 5GB a month, as I don't do movies.
    As for power drop outs, I strongly suggest a decent size UPS on the computer, modem, phone base station etc, make sure you can get at least 1 hour economical usage out of it. And a small inverter you can charge small accessories off in the car.
    Check out the Telecommunications Industry Ombudsman website. The keep statistics on how many claims are made against each ISP to them and how far the claim is carried.
    A while back if you wanted good service from an Australian call centre you'd use Internode. I'm currently with TFG Servers who are small enough that I know the names of the people who work there.
    Melb. Vic.
    Had Optus Cable for a few years now. Nothing to cheer about but works well and no problems with drop outs or after sales. $79 per month, includes home phone 120GB download.
    (Also, recently learned if you ring the call centre, just keep pressing # and you get Tim from Sydney rather than Kevin from Mumbai)
    Western Victoria
    I have set up and fixed quite a few broadband installations.
    I'm not with Telstra but in my experience they are second to Vodafail in poorness of support but their equipment is the best.
    When my Vodafail prepaid mobile broadband expires I'll be switching to Telstra.
    For ADSL I'm with Primus which runs on Telstra equipment in the local exchange. It suits me although does get a little slow after I've used my 1Gb.
    When dealing with Telstra, insist on speaking with an Australian and not their Singapore call centre. Note the date, reference number, who you spoke to and what was discussed. Make sure they note it too. It may take several calls to sort a problem and you will get conflicting advice.
