Thread: Defender 04 brake light fault
    LeHoyne Guest
    Hi there, first time posting as new to being a lro though long time admirer of LR.
    Just noticed the other day that the brake lights don't illuminate, they did work, though I think I may have done something when driving on severe corrugation on the way to cactus bay in SA. I looked at the fuse box under the seat and to my untrained eye, everything looks ok. All other electrics are fine and not sure where to start....help!
    help in the form of a multimeter
    Hi LeHoyne
    Welcome aboard to the forum.
    When you get the chance, buy yourself a cheap multimeter from somewhere like a DickSmith or Jaycar store .
    There are some booklets on how to use multimeters available from those same stores, armed with all that, you should lean a little about electrics and this knowledge is power. ( pun is intended )
    find out how to;
    measure potential across two points, this shows a open circuit.
    measure current, this shows a closed circuit.
    resistance, with less resistance the more current flows through a circuit.
    learn the applications of Ohms law. ( E = I x R ), ( I = E / R ), ( R = E / I ).
    The basic power equation is a easy one also. ( W = E x I )
    E is voltage
    I is current
    R is resistance
    W is power
    Handy knowledge to have if you or someone that you meet, are having electrical problems when well away from help.
    Logan Village area S.E. QLD
    Welcome to the forum
    and thanks Arthur for your informative post
    Series Landy Rescue
    Our FB Page..
    Dec 2009
    Meadow Springs, W.A.
    Hi,
    Welcome to the forum and good to see you on the Powerlines today.
    Phil.
    LeHoyne Guest
    Thanks for the top tip @wrinklearther. Will pick up a multi meter tomoz and have a think of my problem.
    LeHoyne Guest
    The power lines trip blew my mind Phil. I still can't believe what we did up and down those rocks. I can't wait till the next trip.
    Nov 2006
    cardiff ,NEWCASTLE.
    G"day & welcome to the forum....
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
