Results 1 to 10 of 23
Thread: RRS Snorkel - Options
    I am going on a trip next week where river crossing may be up to 500mm. While this is Ok for a RRS it has refocussed my thoughts on a snorkel for the RRS and options.
    I guess there is the OEM RAI which is expensive and requires modification to turn it into a snorkle.
    Could make a temporary home made snorkle like Carver has done but I guess I would prefer something permanent.
    What about a Safari Snorkle? I cannot find a listing but of course there is a D3 version. Does anyone know if these will fit a RRS - the front guard body work is different but I suspect the angle of the windscreen piller is the same as is the air intact hole and I suspect the under bonnet plumbing.
    Other ideas appreciated.
    May 2011
    Orange Grove WA
    Quote Originally Posted by garrycol
    I wonder if the RRS sport part number is the same as the D4 part number VPLAP0018. Have found plenty of RAI pics on the current Sport. Just need to find someone that has a safari snorkel fitted....fingers crossed you will.
    Aug 2010
    Jimmy Salsa / Black Betty - RRS has one fitted.
    He has posted many 4wd video's on uTube of his RRS in the Watsgans & Blue Mountains. Do a search either on this forum or Disco3.uk for info.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    The LR RAI's are different between the Disco & Sport.
    The rake on the windscreen is different so one is slightly longer than the other & the angle is different to compensate for this. This will also mean that the lower section is also set on a different angle.
    They basically are the same fitment for both units.
    Safari don't make one for the Sport.
    I actually like the look of the LR units, but some will disagree.
    Feb 2009
    It'll say in the owner's manual, but surely it'll do 50cm?! I thought the D4 was 70-ish... And the recommended wading depths always seem very conservative to me.
    Plenty of good reasons to get a RAI/snorkel tho.
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Quote Originally Posted by discotwinturbo View Post
    Part numbers are different but I have found on some items the differences are minimal.
    Quote Originally Posted by ~Rich~ View Post
    Jimmy has a OEM RAI that has been made waterproof - not a snorkel as such. I have done a fair bit of research and came to the conclusion there is not a standard snorkel that fits - so asking here if I had missed something.
    Quote Originally Posted by sniegy View Post
    Thanks for that confirmation - I also like the RAI but it is a bit expensive and requires a bit of work to turn it into a snorkel. I guess I can do a modded Carver temporary version using some pvc pipe and some gaffa tape to hold it onto the intake on the guard.
    Quote Originally Posted by Stuart02 View Post
    Not worried about the trip - yes fording depth is 700mm. This just focussed my thoughts that I do need to get some type of snorkel and it would seem the only viable option is the expensive RAI and then make it waterproof.
    Feb 2005
    i noticed a RRS in a caryard on tuesday that had a snorkel fitted, it actually looked quite good, toughen up the look of the RRS
    I think you will find it is not a snorkel but the OEM Raised Air Intake (RAI). Land Rover Accessories Online Catalogue | Raised Air Intake
    Feb 2005
    er yep tahts looks like the one
