Results 1 to 10 of 13
Thread: Rear end EAS droop, with pics
    Oct 2010
    Carindale, Brisbane, Qld
    I am having a drooping issue with the rear of my RR. I know I have to solve the leak problem, which I will, but why is only the back going down and not the front? Should the vehicle try to self level as the rear deflates?
    See two pics, one is yesterday 6pm, two is 6am this morning. 12 hr gap.
    6pm yesterday:
    6am today:
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Its got worms and an itchy bum
    Dec 2009
    Tyrendarra Vic (South West Vic )
    As part answer. Yes it should self level itself. Mine had a slow leak, so when parked it was fine. But most mornings it would be down near bump stops . Never took long to pump up. Just never got around to fixing it. Usually had a fault which I cleared with BBS EAS Kicker. Was a lot better if driven every day but my driving patern was only about once a week.
    Maybe stuck valves in valve block. Had mine apart a few times. Even with new "o" rings sometimes they can be crimped on reassembly. As I found out
    Gary
    Oct 2010
    Yesterday I pulled both rear airsprings out (wow, what an easy and fast job! - 3 mins each to remove and 4 minutes each to reinstall!).
    I took the bellows of at the bottom where they were leaking and cleaned the bead and the piston surface which had a lot of crud. The result??!? - nothing, they still leak. Damn.
    Looks like I am up for new bellows, which begs the age old question, go new bellows from airbagman, or go GenIII on the rear?
    Pic one shows curd in airbag bead,the cleaning of which did not help things. Pic number two shows the air leaking from the lower bead. Pic 3 is the sad state of affairs this morning after being on high setting at 5pm last night.
    Douglas Park, NSW
    If they're leaking at the bag/top hat joint, you might be able to seal them with tyre bead sealant.
    I haven't had to resort to this myself but I have seen it done a few times over the years.
    Apr 2007
    South Australia
    How old are they?
    In my personal view it looks odd that they appear to be leaking all around and not in one or two spots.
    Mine are just starting to go on the p38, the bags are 10 years and 150,000 k's old. But mine are starting to leak at cracks and not the sealing bead, the same place the only non replaced bag on my classic leaks. Holds air fine if I put it in high height for a few weeks, but leaks to bumpstop in half an hour in standard height.
    Might take mine out and give them an armarol bath I have been told this can "plump" up the rubber and seal aging bags to get another few years out of them. My issue now is the P38 is lucky to be driven once a month.
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Dec 2009
    If I still had mine I'd be going for the GENIII. Just my thought tho
    Gary
    Gosnells
    Seems you've done the Hard Yards and positively identified the bags as the only (?) source of leaking...
    I replaced all of my LR Originals with ARNOTTS on the '95 Classic, not leaking, but had cracks you'd fall into and never - ever be found. - Which gives me the option of spending $100 or so each and re-rubbering them to use as emergency spares. ARNOTSS are crimped on each end, at least on the Classic.
    China is correct, replacing the O rings inside the valves is a Black Art, and yes, one of mine is leaking (LH rear). - I've got in-line taps to each bag as well as the Schraeders spliced in. - Just turn off the LH rear at night...
    Seeing that they're so easy to R/R, try all of the above suggestions... got nothing to lose!
    Self-levelling does'nt hapen on mine, otherwise the system all works as the handbook says
    hobart
    AIR BAGS
    I put Arnotts on my hse some time back.
    Firmer ride on highway setting and definitely softer on off road setting.
    Somewhat longer so gives the option of using computer to reset with a cable and series to usb adaptor from Paul at Hardrange.
    Don't seem to have any downside except that you have to spend your hardearned.
    Jan 2012
    Bendigo
    An amoral bath mmm, I may not be in dire need of new rear bags afterall. My Classic once stopped leveling itself overnight (it may be advantage!) but it was a nacked delay relay; interestingly it stopped the eas diag. software from communicating too.
    I've always used a thin smear of rubber grease on both sides of the outer orings, and the top of the inner orings on the solonoids, don't know if it's good practice or not, but it stops them shifting about when assembling.
