                                                7th January 2012, 08:25 PM
			E Diff
					G'day all, I was driving out of a track down near Cowaramup Bay just recently when I had to use rock crawl for a tricky section.
 I noticed when crawling out of a lime stone hole, that a diff illustration came up on the dash.
 Does this mean I have the E diff option, and does it come on automatically when it senses wheel slip?
 Darren
                                                7th January 2012, 08:42 PM
					I would assume that you have the factory Nav, In this mode you will see the 2 diff lock symbols but you may only have 1.
 It always shows both, but shows when it is locked as it turns red.
 The diff option for centre & rear are not user selectable, they are fully automatic.
                                                7th January 2012, 11:02 PM
					G'Day Pete, no , I don't have the factory Nav system.
 The diff message was from the dash??
 Thanks for the reply.
 Darren
                                                8th January 2012, 06:44 AM
                                                #4
			Ediff
					G.day Darren
 It seem that you are seeing the steering angle indicator which is active in rock crawl. When you turn the steering wheel enough the display of the wheels changes indicating which direction you have turned the steering.
 You can test it with the vehicle stationary.
 Ivan
                                                8th January 2012, 08:54 AM
                                                #5
					Yeah ok, thanks Ivan. I will check this out.
                                                9th January 2012, 06:42 PM
                                                #6
					FWIW - Your centre diff IS an e-Diff. The rear e-Diff is an optional extra.
 HTH
 M
