Lugging an engine (operating at too low revs for the gear) is bad for the engine and bad for the gearbox/driveline. You will have high torque pulses - especially with a 4cyl.
My old engine rebuilder's motto was: revs/working hard doesn't kill an engine - sitting at a constant speed on the highway is what kills engines.
That may only be partially true, however I find that hard work and occasional high revs don't hurt a diesel in the slightest. On the contrary, it probably helps remove carbon deposits...
EDIT - not letting an engine idle is very good advice. Driving as smoothly as possible (brake/clutch etc.) is also good advice. Sitting between 2000 and 3000 is also good, but don't be afraid to put the boot in from time to time.
