I would never think that shockers are causing the shakes.
Even a bad steering damper would not be the cause of shakes but sometimes a good steering damper will cover the shakes up.
What you are describing is common with wide wheels / offset too far out.
Do you have original rims ?
Next I'd check that the toe-in is correct, even if you have had a wheel alignment done a lot of places do not understand that a Defender needs 0 - 1.5mm TOE OUT, or -ve 1.5mm toe in . Most other 4x4 need +ve toe in.
That would cause your problem.
