The centre difflock is engaged by shifting the little gear lever to the left and disengaged in similar fashion by moving the lever to the left again. this can be done in "High-" and "Low-" ratio, even "on the move" although some people may have reservations doing so.
The difflock locks the differential in the TC, making basically a straight connection between front and rear axle, both of which will then rotate at the same speed. The differential in the TC allows for different rotational speeds of the axles as, e.g., when turning where the rear axle will have to run a smaller turning radius compared to the front axle, hence moving at lower speed. You will feel that your steering will be a bit "stiffer" when difflock is engaged. All this means that your difflock should be disengaged on grippy surfaces to avoid transmission wind-up and consequently damage to the TC. Use it on loose surfaces when there is any risk of getting stuck.
And yes, you can use low ratio when pulling your boat out of the water (in fact, it is rather recommended to do so).
				Johannes
There are people who spend all weekend cleaning the car.
And there are people who drive Discovery.
