Results 1 to 4 of 4
Thread: 80 inch swivels
    Oct 2011
    Burra NSW
    80 inch swivels
    G'day guys, just after some more advise! The front swivels on my '52 80in are leaking quite badly, any ideas on a fix? The chrome balls are reasonable but there is a little too much play in the splined bushes, do I do a full new/ reco unit if available or is there a kit to refurb my existing ones? Once again your advise is appreciated.
    australia
    front swivels
    Quote Originally Posted by Summiitt View Post
    hi summit have just taken a80 inch 1952 apart has good swivels half shafts not worn ring 0428732001 brisbane
    East-South-East Girt-By-Sea
    1.20 MB
    If it hasn't already been done you can retrofit it with the later Railko bearing kit. Make sure you get the kit and not the SIIa/SIII bushes as the pins are different.
    Timj is offline Wizard Silver Subscriber
    Brisbane,Qld.
    I also vote for changing to the later Railko type bush. Very easy change and totally invisible from the outside. Can't think of any reason why it would be worth keeping the brass cone setup really. Despite that though, have you tried adjusting them up by removing the shims? A new swivel seal would be a good idea too of course.
    TimJ.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
