Results 1 to 10 of 23
Thread: New laptop suggestions please
    Time for a new laptop for work apparently , my pick, up to $2000.
    Apart from general work stuff which is mainly MS Office, its other use will be crunching photos in CS5. These are big fioles, typically 80 MB but can be up to 500MB for a pano.
    My current pick is this but I'd welcome any suggestions:
    Asus N73SV-TY572V
    Core i7 2670QM
    17.3" LED HD+
    1.5TB HDD
    12G RAM
    BLURAY RW
    GT540M/2G
    WiFi N
    Bluetooth
    Webcam
    USB 3.0
    Win7 Home Premium upgraded to Pro.
    ASUSTeK Computer Inc. - Notebooks- ASUS N73SV
    Aug 2010
    melburn
    Going from what you said about the image files, any brand should suffice but try and go for a laptop that has a nvidia graphics card that has "cuda cores". ie "GTX- ####" etc,
    CS5 will use your graphics card (the cuda cores) and things will become very fast. You will need to download a support file to update your CS5 so it works with the graphics card you have. Just google cuda cores CS5 and you should be right.
    Jul 2009
    Hobart
    Hi,
    I went for a Lenovo on advice from my son who services lap tops, he says they are a solid unit, well built and have quality components.
    I've had this one nearly 3 years with no problems.
    Toowoomba
    My 2c:
    I work on desktops & laptops a fair bit for work & muck around with them in my spare time.
    IMO Dell is best. Now I know everybody has a "Dell horror story", but in truth they work well for us, partly because the machines run well, but mostly because of their great customer service & prompt on site repair, which is an essential in business. My most recent on has had 1 issue in the last 18 months that was sorted the next day. We have at least 8 Dells at work that have had no issues in the last 2 years. (and BTW, I track mine all over the place & to & from work every day)
    So simply for contingencies sake get a business Dell & a onsite support plan for the expected life of the machine.
    I bought the equivalent spec model in the H53SV range a few weeks ago. Saw it in HN for ~$1800 picked it up at MSY for a bit under $1200. No complaints about it.
    Don't know much about CUDA but the NVIDA spec page for the GT540M says it supports CUDA - "96 CUDA cores". GeForce GT 540M
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    I'd love to say Mac, as they are robust, fast and reliable....
    But here at work I'm stuck with Lenovo - which whilst lack lustre do work consistently.
    Melrose SA
    I think your choice is fine, presume that it has 2 drives I would take one out and put an SSD in for the boot drive.
    I would then run a 64 bit version of Windows and take up some of your RAM and run a RAM Drive for the files you are processing.
    Should be more than adequate.
    WA
    We are forced to buy Dell.
    This will be my new machine.
    DELL XPS17
    PROCESSOR 2nd generation Intel® CoreT i7-2860QM processor 2.50 GHz with Turbo Boost 2.0 up to 3.60 GHz
    MEMORY 8GB Shared Dual Channel DDR3 Memory
    HARD DRIVE 1.0TB 500GB 7.2k HDD x 2
    VIDEO CARD NVIDIA® GeForce® GT 555M 3GB graphics with Optimus
    HD DISPLAY 17.3" FHD (1080p) with 2.0MP HD Webcam
    INTERNAL OPTICAL DRIVE Tray Load Blu-ray® Triple Writer (reads and writes CDs, DVDs, BDs)
    BATTERY OPTIONS 90 WHr 9-cell Lithium Ion Primary Battery
    It was either the above or an M4600 workstation laptop. The M4600 would probably last longer, but we have also been forced over to leasing rather than purchase, so it just needs to last the lease. The M4600 was also a lot worse value for money.
    The machine will be used for modelling, simulation and image processing (as well as the usual).
    Re the Dell comments. I think they're quite good machines for the price and we use their Vostro laptops for our techs, and desktops and servers for our customers.
    But there is better buying out there if you compare the Dell specs to others, hence me looking at the Asus. I've used an Asus M51V for 3 years now with no problems at all. My two boys got an N53S each for xmas and they're awesome machines.
    Oct 2003
    Montrose, Vic.
    One thing to keep in mind,and it definitely applies to ASUS, is that they release the same machine in several different configurations - and some can be significantly better value than others.
    I recently bought a Asus U31SD laptop for my daughter. (Great little 2nd gen. i5 13" machine)
    The model we originally looked at was obviously targeted at the consumer market (Win 7 premium, 6 cell battery and 1 year warranty.) After some poking around, I found I could get the same machine, but speced with Win 7 Pro 64bit, 8 cell battery and a 2 year global warranty for exactly the same money. - obviously different model targeted at a commercial market.
    So if you settle on the Asus - might be worth checking out if that also applies to the N73SV.
    As for Dell, I agree the commercial Dells are good machines (I've owned 4 and managed about 400) - but recently I think there are better units around for the money.
    Tombie is right the best hardware you would get is an Apple... but not 17" for your budget.
    I used to be pretty anti Apple.... but honestly, my current Macbook Pro would be the best piece of laptop hardware I have ever used. (Even running Win 7 In Vmware.)
    Good luck with it...
    Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
