Thread: Chassis rust protection
    Nov 2008
    Have just about finished painting the outside of my repaired chassis, and want to do something about the inside before starting to bolt things on.
    What's the best for this? I have read about fish oil, lanolin and various branded products, but would be keen to hear from someone who has done it.
    What to use and how?
    Roger
    South Australia - Port Pirie
    Hi there
    When I repaired the rear cross member of the series one Fire Engine I used fish oil
    You buy the presurised cans of fisholene (not to sure of the spelling) from any local auto parts store and sprayed it into the rear cross members after repairs and this will potentially give it a barrier to prevent any aditional damage.
    All the best
    Wayne
    australia
    waxol
    spray waxol half inch tube with 2 mill pin holes stong air pressure my 109 done this way buy a brisbane company not trading now now hope this helps jim
    Narrogin WA
    I use Penetrol - it was the only product that worked for me on an outdoor test piece experiment, which lasted 12 months,
    Cheers Charlie
    Oct 2007
    Red Cliffs
    Rust
    On all of mine I clean out the rails best you can with water, let it dry in the hot sun then using a karo wash gun at high pressure pump about 4 litters of fish oil in through every hole you can find, roll the chasses over part way through.
    Make sure you prep and paint chassis first as oil will run out for many months if not years, smell goes away after 1 or 2.
    Very popular with cats.
    Dennis
    Yass NSW
    For areas where i can get good access I use cold galvanising spray. This will provide a longer protection period than fish oil. There is no reason why you could not use both though.
    Regards,
    Tote
    Lostkiwi Guest
    You could always go the "environmentally safe way" and pump in used diesel engine oil!! ..... works really good
    [I don't do it]
