Results 1 to 8 of 8
Thread: Cleaning engine bay
    Feb 2010
    melbourne
    Cleaning engine bay
    Hi all. Does anyone have any advice on cleaning my Puma engine bay. Pressure washer, degreaser etc etc? It's pretty dirty oily etc but also worried about having weeks of engine electrical drama if I pressure wash.
    Thanks.
    I just hose with degreaser, leave it for a while then high pressure off. Haven't had any problems yet on all my 4wd's or cars. Puma included
    Rob
    Kingston, Tassie, OZ.
    I would warm the engine (NOT full operating temp!!) and use neat truckwash or similar detergent. (I use a product called G101 from Autosmart
    http://www.autosmartaustralia.com.au...photos/101.jpg
    Leave for 10 minutes Then hose off with low pressure.
    JC
    Brisbane,some of the time.
    One think to watch is if you take the small plastic cover off the top of the engine,you will see water pooling around the injectors.
    I always wipe this area dry as you wouldn't water to seep down through the rubber seals into somewhere it shouldn't be.
    Jul 2011
    Yarrawonga, Vic
    use degreaser then high pressure hose,
    spray everything (except breather holes & air inlets obviously)
    its not going to cause a problem unless you have a fault.
    better to find a fault in your driveway this way where you can fix it than getting stranded in the outback somewhere
    Feb 2010
    melbourne
    thanks all
    I'm off to try it now.
    curious
    Quote Originally Posted by portafilter View Post
    How did you go with it?
    Quote Originally Posted by wrinklearthur View Post
    It's that dirty i am still at it,got the head torch on
