Hi Disco EMU,
Fairly easy job as I did this myself....
You need to unscrew each of the knobs on the sticks to completely remove them - handbrake is the same but may just pull off as apposed to screwing it off.
Be careful not to lose the round rubber ring which holds the gator to the knob, you'll see what I mean when you take it off.
good luck with the handbrake, it was a pain in the proverbial :-D
Lp
