Results 1 to 9 of 9
Thread: Damaged tow hitch
    Dec 2010
    Perth WA
    Damaged tow hitch
    My wife reversed into a sign post yesterday and as luck would have it ended up breaking part of the green knob and looks to have bent the pin that is attached to the key/locking mechanism
    The question is:
    1. Will I need to replace the entire cast section or is there a chance that I can get replacement parts
    2. Any idea what a replacement hitch would cost and the best place to buy it?
    3. Is it safe to tow in this condition even though it does don't appear to have unlocked (me thinks not)
    And yes we do have reverse sensors and a camera
    NavyDiver's Avatar
    NavyDiver is offline Very Very Lucky! Gold Subscriber
    Feb 2010
    Quote Originally Posted by MC D4 View Post
    The question is:
    2. I brought one then sold it after getting a nice one which didn't drag while off road. Landrover dealer in Doncaster for about $500. I bet you might be able to get one from the UK at a better price or just get the upgrade
    I wonder if you visted a locksmith if they might be able to help you? It is a locking mechanism. Might not hurt asking one.
    If it makes you feel any better my better half drove mine into the garage with a spare loaded on the roof rack- OUCH, Our gararge door took a lot of panel beating
    Dec 2009
    Ranelagh, Tasmania
    You can buy the locking mechanism separately for about $30. Part number is KNW500010.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Sydney, Australia
    A Mitch Hitch would be cheaper than a new OEM one, and better.
    Dec 2010
    Perth WA
    Thanks for the responses thus far. I tried to remove the hitch and as suspected it is not going to be straight forward. Key in and turns to the unload position but just cannot get the green knob to turn at all!!! Now key refuses to come out. Any ideas (pic attahced)
    Sydney, Australia
    You can drill out the lock and replace it.
    Nov 2011
    Surf Coast
    and replace it with a mitch hitch! (only mount it when u need it then it can't be damaged!)
    D3mike
    NSW SW Slopes
    I couldn't turn the key very far on mine after not having removed the coupling for almost 2 years, but copious amounts of WD40 around the key and green knob and some gentle tapping of the knob got it moving after a while.
    Dec 2010
    Perth WA
    Thumbs up
    Good news guys... It ended up being a nice easy fix:
    1. Select 1 x large shifting spanner
    2. Lever between bent shaft and shackle eye
    3. A little elbow grease to straighten the shaft
    4. And presto the locking mechanism is free and working as it should
    5. Put credit card back in the wallet
    Thanks to those who tried to assist...
