Results 1 to 6 of 6
Thread: VDO tachometer for 300Tdi?
    Jan 2012
    Melbourne, Victoria
    Hi, I am looking at fitting a VDO tachometer (part number 333-156) in my Defender, I'm just wondering if anyone has one fitted or are they even useable with the 300Tdi??
    Thanks...
    Douglas Park, NSW
    There's some good info here:
    Defender 300 Tdi tacho - easy to do?
    Jan 2009
    Samford
    I have the VDO 333-155 which looks to be the same, just with a higher rev limit. It's quite an easy job. Mount it where the clock is and jumper the 12V+ power and earth from the temp and fuel gauges (green wire I think). Run a wire from the "W" terminal on the back of the alternator. I guess just check that you do have a "W" terminal.
    James.
    Jan 2012
    Melbourne, Victoria
    Thanks for the info, I do have a "W" terminal as I've got a 100amp alternator fitted so thats no problem. I'm keen to get a tacho, in particular a VDO one as they match the original gauges in my vehicle so will look in to it more seriously.
    May 2008
    Frederickton NSW
    Hi Guys.
    I have a 4000rpm tacho (333-156) that i had in my TD300. Worked perfectly in that car and has been sitiing on the shelf.
    Eric
    Last edited by Scouse; 1st February 2012 at 07:42 PM. Reason: No trading in the general forums. Stick to the markets or deal via PM thanks.
    Nov 2008
    Bruthen, Eastern Vic.
    Eric,
    I will take it if I am not too late?
    Terry
