Results 1 to 10 of 14
Thread: 5.4 L engine on the way, what exhaust should I fit?
    Dec 2011
    My new engine will have 5.4 litres of top hatted goodness, Forged crank, forged high compression pistons, special conrods, stage 3 heads, good cams, reworked inlet trumpets with lots of nice-to-haves thrown in, including a new ecu program from Mark Adams who has also supplied Bosh injectors, which he recommends. It should make good power and plenty of torques.
    The car currently still has a pretty standard exhaust system. Although my service provider comments that the standard headers are quite good, it seems to me a shame to throttle the new engine with a standard exhaust and I'm interested to know whether anyone has put aftermarket extractors on their Rover V8s, and what the results have been. I will really welcome your comments and insight.
    So, are there stainless headers available, and has anyone tried them or does anyone have any recommendations?
    As I'm sure you all know, the current exhaust system takes a wondrous detour from the driver's side of the car, across the car at right angles, to join at the passenger side. Has anyone succeeded in fitting a dual system from the headers to the tailpipes?
    I'm also wondering whether anyone has fitted free flow catalytic converters and a 3" system, either single or double?
    Apr 2010
    Lower Hunter Valley NSW
    I've got Genies on my Disco 2. I can say that although I have a stock 4L, the extractors made a noticeble difference in torque and fuel economy. With mods, the extractors would give even better results as the stock manifold would be your bottleneck.
    Dec 2011
    Quote Originally Posted by banarcus View Post
    Thanks for the heads up, in order to follow up I called Genie in Qld and spoke to Brad who told me that they only make them for the 4L engine, suggested to me that they wouldn't fit my engine ????? and that I'd need to get them custom made.
    back to square one.
    May 2003
    On The Road
    if you are running LR heads,,
    they almost have to fit--
    size of the port maybe?
    Douglas Park, NSW
    Quote Originally Posted by Sydr View Post
    back to square one.
    So they said they'd fit a 4.0 P38 or just a 4.0 Disco II ?
    I haven't been able to find any 'off the shelf' extractors for the P38 anywhere.
    Nov 2006
    narellan, sydney
    I have, they are stainless steel aswell.
    I cant remember their name, but their logo is a green and gold (mabe silver)oval. Luckily the company who supplies and fits them, also includes heat shields, to stop other parts in the engine bay melting.
    andy
    IIRC Isn't there an after market ceramic coating available now to reduce radiated heat from exhaust headers?
    Damn! that sounds very nice Is this an import or local confabulation and are you retaining the standard transmission?
    Dec 2011
    Quote Originally Posted by Hoges View Post
    Engine is being built by an UK company, see
    V8Developments Ltd.
    I've briefed them and Mark Adams (ecu program) on my requirements - p38 RR, towing car, want big torque not huge revs, and also on my driving style - hit the 'sport' button as soon as it fires up but tend to use the gear selector - dislike the accelerator kick down. So I've no plan to change the transmission which has never given any hiccups and which I'm told is very strong and should cope admirably with the extra hp.
    The engine is promised for completion today, and I've ordered some ancillary parts that seem sensible to replace while I'm doing a heart transplant - all rubber hoses to engine, tranny, and heater, other rubber bits like engine mounts, tranny oil cooler, engine oil cooler, heater matrix, radiator, new fan and viscuous coupling - whatever you would think of as sensible to replace.
    I'll also replace the blend motors (carked a long while ago), have just had the dropped roof lining beautifully repaired by a v good local trimmer who is v reasonable, will replace the rusted sun roof frame when I find a replacement (seperate post) and will fit new airbags, shocks, eas by pass system. Brake discs have just been done.
    It was "do it properly" when the engine developed a new liner, or "toss it and buy another Rangie". To my mind, after doing the numbers and in the light of the fact that I love my p38 which I've had since new, no contest. I've had the massive depreciation once, and that is quite enough. Others may buy a Toyota Pious as their gesture to recycling, I'd rather repair than replace.
    I'm interested to find out whether a hi comp engine with all the nice bits will use rather less juice than the 21 - 22L per 100 that I see when I call up the numbers on the display. Since I only call them up when I wish to cheer myself up on long trips, that is academic.
    Douglas Park, NSW
    Quote Originally Posted by andrew e View Post
    andy
    Great .
    Do you know if they're a local manufacturer or from overseas?
