Results 1 to 4 of 4
Thread: Ashcroft transmission 5speed kit
    Sep 2009
    Dalby, Qld
    Hi everyone,
    I was just wondering if anyone had fitted or considered fitting one of these Ashcroft 5 Speed Kits, it uses a LT77 gearbox and the Series Transfer case. You can use the LT 230 transfer case but it is not my prefered option.
    Ashcroft Transmissions - Series 5 speed kits
    I would like to know what are the Pros and Cons , and is it worth it.
    Thanks Jeff
    East-South-East Girt-By-Sea
    1.20 MB
    You lose your ability to have a rear PTO output for a winch etc.
    Sep 2009
    Dalby, Qld
    Losing the ability to have a PTO does not worry me, I just really like the idea of a five speed box. I was just hoping someone on here may have put one in or know of some one in the UK that has fitted one.
    Jeff
    Northern NSW
    I read in one of the LR mags I get.It's quite easy if you can find a short bellhousing and box out of a 2.5 fender bolt the ashcroft conversion on shift the engine mounts forward 100mm I think. You have to use the series trans box cause of no cv's in the front diff I have wondered if the fender axles fit the series diff. To me it would be good to have a 5 speed. Cost wise hard to say cost me $2500 for an overdrive.Are there many 2.5 fenders around being wrecked?
    Cheers Will
