Thread: Faults/Error codes
    Scarborough QLD
    Faults/Error codes
    Just recently I have been getting a transmission fault. The car still runs OK but I lose command shift. Turn off and on again and all is well for a while. I have also started getting HDC/DSC faults and the suspension lowering. Once again turn off and on again and all is OK.
    I have just received my Faultmate and will be looking at the error codes this weekend. In the meantime, from information on here and Disco3.co.uk, I have ordered a new brake switch.
    This has only recently started since we started to have all the rain. Possibly connected??
    TIA
    Ivan
    Feb 2010
    Mount Martha
    Quote Originally Posted by Ivan View Post
    TIA
    Ivan
    Ivan, have you checked that your battery is OK? I had mine replaced recently and it is only two years old.
    When the LR mechanic plugged into the vehicle, all sorts of fault codes were coming up.
    Cheers, Craig
    Scarborough QLD
    Craig
    Will check this weekend.
    Ivan
    Scarborough QLD
    Thanks to the advice on this forum I think I have solved the problem. Checked the battery and it was showing 12.65 volts. So I replaced the brake switch (as mentioned on here) and it seems to have solved the problem. Thanks to you all.
    Ivan
    Aug 2009
    Orange, NSW
    This problem has no recurred on my vehicle since changing the brake switch. Well done Ivan.
