                                                9th February 2012, 03:35 PM
			High Volume Oil Pump
					Hi Guys,
 I have a Real Steel High Volume Oil Pump fited to my RRC. The pressure relief valve has stuck in the bore, and I am about to replace the pump housing to fix the problem, how ever the relief valve with the real steel kit has a hole through it, that the std ones does not have.
 Does anyone know if the hole is requred?
 Phil
