Results 1 to 2 of 2
Thread: Td4 flywheel locking tool
    Revesby NSW
    Hi I have to change the harmonic balance on our 2005 TD4 and I was wondering if anyone has a locking tool the I can use or hire in the Sydney area for flywheel as our car is a Auto
    If you can call on 0419420806 if you have one that I can use
    Revesby NSW
    TD4 flywheel locking tool part 2
    HI all
    I finally made a tool to lock the free wheel this is the only way to remove the retaining bolt we used a 8 foot length of scaffold pipe with a 3/4 socket set plug a 22m impact socket and a couple of good hits on the end of the socket bar the with a lump hammer before it finally moved, after also using various impact hammers I even tried a 1 inch rattle gun it seamed in the end the big bar was the only way !
    On reflection probably the hardest part of the job is the removal of the starter motor.
    So if you do have the pleasure of changing a harmonic balance feel free to contact me if you want to borrow the tool if you are in the Sydney area.
    The joys of owning Land rovers
    Braggy
