 Originally Posted by
Glynhouse
				The blue wire that goes into the rear of the black socket is very thin but appears the plug is epoxy filled at the rear so can't do anything about changing that ! Normal ??
 The wire is thin because it was only intended to power some tail-lights.  The D4 the wire is protected by a 10A fuse so possibly the same with the D3.  If I was to start towing a 4 wheel braked trailer I would replace the wire to the plug but the wire should be sufficient for 2 wheel brakes.  It might even be satisfactory for 4 wheel brakes if using a proportional brake controller because the longest time the brakes are applied is probably whilst stopped at traffic lights so only low power is used.  Better to replace the wire though - epoxy can be removed.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
