Hi Lotz-A,
If you purchase the vehicle with Sat Nav there is at the moment no way of interfacing other mapping (Ozi-explorer for instance) software on that system.
Also with the mapping software on the factory Nav the update comes out when the mapping company that has been supplied the agreement to supply updates when they want, we were originally told 1-2 times per year & have only seen 2 updates so far.
I was using just a basic Garmin unit, which I thought was very good & no where near the cost of the Nav system.
I have recently misplaced/lost my Garmin unit & am thinking of buying the App for my IPad to use as a mapping system which is made by Hema, there is also another that is called VNS from memory & am reading the pros/cons from each to decide & again it is still cheaper than buying the factory Nav.
If you purchase the vehicle with Sat Nav you can now buy an inverter that can use the factory screen to fit a reversing camera.
The after market unit was something I & a few others have spotted which is fitted into a vehicle in Russia & uses the std basic no Nav system then converts it to a fully functional Nav/PC unit if req.
I did not opt for the Nav system knowing that you couldn't add extra maps if req. You save a small fortune & if need be you can buyan "IPad" & it's app if needed & still be in front.
Hope this helps in some way.
Cheers & happy hunting.
