Originally Posted by
justinc
Baz,
The V8 box is different in a few areas, that IMO make it a bit of a pain to change to diesel 'spec'. Firstly, the obvious bellhousing and pump housing, but less obvious is the cam profile for the throttle (kickdown) cable is way different, and the governor is a different weight to allow lockup etc at a lower road speed. (Not much, about 10km/hr so you COULD just leave that, the V8 is around 85km'hr, the diesel 75km/hr. Note that in a 110 with a 1.410:1 high range you will have even lower road speed upshifts etc, like 65km/hr to 70km/hr for converter lock in 4th)
The differences in the valve body I haven't been able to quantify, they may be unimportant , affecting shift pressure (Harshness?) etc maybe.
The cam can be changed out for the relavent diesel profile one, but this involves removal of the valve body, and a shaft that can't be done in the vehicle as there is not enough clearance.
JC
