Thread: how to test if heater core leaking or not
    Jul 2008
    Ballarat, Victoria
    I bought a 200tdi discovery that needs some work, i noticed the heater core is not connected to the engine, that is, the hoses are missing, i assume that the heater core was leaking, but i thought it would be wise to test it before pulling the dash apart to replace it
    has anyone done something similar before?
    Gosnells
    Quote Originally Posted by jazzaD1 View Post
    Yes, the previous owner ....
    Avoca Beach
    Connect it up wiith the carpets out and look for water on the floor!LOL
    Regards Philip A
    Feb 2012
    Parkdale, Melbourne
    Yep, it will most likely leak onto the floor from under the dash. Mine dripped out near (or maybe within?) the feet heater vents. Just give it a go and make sure your radiator doesn't get too low.
    Crafers West South Australia
    A stench of coolant from a warm heater core is usually a dead giveaway.
    Jul 2010
    Hunter Valley NSW
    connect your garden hose to some 16mm heater hose and then to heater and turn on the tap... connect another to the outlet to kik to hose to allow pressure to build. if it doesnt hold mains pressure it fails.
    Aussie Expat in NZ
    Coolant will usually leave a white scale around where it leaked. If there is any of it on / around / below the core you will have a leak.
