With the oil filler cap off is the blow by excessive?
"it has just had a complete engine overhaul and is now spewing oil from every joint and seal"
Stealing from the technical thread on "Pistons" is it at all possible that the bores were machined/honed, new pistons or rings used without checking ring gap clearances and now you have rebuilt her as a heavy breather????
The scavenge from the rocker cover through the PCV to the intake hose really shouldnt be dealing with excessive pressures. It is simply a polluction control measure. In a tight engine the breather could vent to atmo with minimal drama.
If your engine is breathing heavy post rebuild you need to find out why?
S
