The windscreen wiper auto operation sensor that I am familiar with is located at the top and on the inside of the windscreen glass behind the interior centre located rear view mirror.
There is a two piece plastic cover that sits behind the mirror that separates apart to reveal a collection of small electrical wires and a rectangular clip about 1" wide x 2" high. The bracket holds what appears to be a collection of small LED's arrayed on a sort of clear plastic rectangle. In my case, the array of "LED's" had become unclipped and when I reset the array into the clip, my windshield wipers did the moisture sensing thing more as I thought it should.
From all this, I concluded that what you probably get when you purchase the new windscreen with attached sensor, is the the clip and perhaps the array. It was not clear to me that the clip was supposed to be separate from the array but if so, it would seem that if one could somehow remove the plastic bracket from the old windscreen, you could then glue it to the new one in hopefully the correct location, and then re-clip the original array back in.
Others may disagree.
