The presumption is that you are wanting a replacement diff center for a Discovery built between 89 -99. Generally referred to as a 'Disco 1'.
'Series 1 ( & 2 & 3 or in roman numerals II & III) generally refer to the original Landrover products built from 1948- 85 (ish)
Back to your disco - prior to Chassis #SALL....MA081991, you'll be needing the diff version for 10 spline axles - after that they are 24 splines.
Search ' Trutrac' & 'Detroit locker' here on the forum - plenty of information
& Welcome.
