Silly question I suppose, but you have tried putting fluid in it and see if it pumps up haven't you ! if the fluid just pumps out you have a fault further down the brake system which needs addressing first.
Hi everyone, the brake pedal on my 1970 2A 88" just goes to the floor and does nothing. I have a replacement master cylinder, as well as hoses, shoes, wheel cylinders, etc.
But what is the procedure for removing, replacing and adjusting the new brake master cylinder? I've done some searching and can't find any answers.
I've already removed the access covers, reservoir and pipes, but not sure how to proceed from here.
1970 Series IIA 88"
1997 Discovery 300Tdi
Its not a fun job.
Access to the pedal boxes is hard.
I always take the pedal box out. If the old master cylinder is siezed, you need to cut the pushrod first, as the pedal has to be in the down position in order to get the pedal box out. I normally use a rat tale file to cut the pushrod, as access is quite limited.
Aaron.
Aaron IIA is correct - believe it or not the easiest way is to remove the pedal box (from inside the car).
Remove the springs from the pedal (if any), undo the bolts from inside, lift it out using a 90o turn, and away you go!
I learnt this trick from this forum when I had to do mine.
There is also an excellent article in November 2011 Land Rover World.
Regards,
The Grey Ghost
Yeah it was full of fluid when I pulled it apart.
Thanks for that. I assume the master cylinder is not seized, as the pedal goes straight to the floor.
Thanks for the tips. I'll order that magazine, it seems cheap enough. I hadn't heard of it before.
1970 Series IIA 88"
It would be better to order the factory workshop manual.
Aaron.
Gumnut - 1953 Series I 80"
Poverty - 1958 Series I 88"
Arnie - 1975 710M Pinzgauer
