Originally Posted by
goingbush
Removed my Turbo heat shield to access /remove the oil cooler water pipe and found the Heat shield had almost rubbed thru it
Under the turbo shield (3 bolts to remove) you will see this rubber pipe .
here is the damage to mine
I got to it just in time, This could result in a catastrophe if you don't inspect / remedy. You could just bend the shield but I'm not putting mine back on.
I also removed the pipe as its not needed anymore because it normally runs to the EGR cooler which I don't have. Another thing not to go wrong.
Mine is now blanked with some silicone hose & a bung.
I also found a broken manifold stud - time to remove & deweb I suppose.
May I ask what year D2 you have? Did you take out the EGR cooler, the reason I ask is my 1999 D2 wasn't fitted with an EGR cooler, the hose from the oil cooler passed directly to the bottom of the radiator, then out to the fuel cooler, from there , via a thermostat on the back end of the fuel cooler, either to the heater matrix, or back to the water pump inlet, after the thermostat opens at 82 degrees C. [ A hose from the plastic expansion tank joins this return.] The photo of the small hose from the oil cooler shows a hose about to fail, thru the heat generated in this area. These hoses should be inspected occasionally. The broken stud is a result of the high temps. and repair is mentioned elsewere in the forum. I hope I'm not speaking out of turn, but any disruption to the cooling system on a TD5 can be disasterous, Bob
I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
A bookshop is one of the only pieces of evidence we have that people are still thinking
