 Originally Posted by
harlie
				That actually looks like the same cheap arse regulator I take camping! Mine came in a kit, and I assumed (and budgeted) that I would chuck it and get a decent one, but it has performed quite well. It has 2x80 panels feeding it and V measured at the elec panel never goes above 13.6. First thing in the morning when things are cool and the batt is down a bit I see over 9.2amp, this of course drops as V approaches 13.6, and it will hold V at 13.6 all day (with 60L evacool running) until panels loose light. I increased output by about 30% (7.1 to 9.2 amp) by getting rid of the small cable, replacing with 6mm ($50), and taking the regulator off the panels and mounting beside the battery – this way the high voltage on the panel side (~21v) is taking the voltage drop over the long cable and the very short run to the battery allows the regulator to sence the lower voltage better.
      Sounds to me like it is hooked up incorrectly or not working correctly - if you have 16.5v at the battery, I would consider that closed circuit, panel will be about 19-21V, minus voltage drop of the wire (no doubt quite small diameter), minus internal resistance of old battery and change of state inefficiencies ect ect and that would be about right, you wouldn't see much current at that level and your poor battery is in hell.
   Dropping to 12.6 with fridge under heavy cloud I would expect with cheapo panels. I’ve notice low light (heavy cloud) performance with my camping kit no where near as good as the BP kit, to the point where the BP panels output near 30% of capacity as apposed to 10-12% for the cheap ones (that’s side by side operating!).
As a side note – when shopping for my camping kit I found quite a few (cheaper) sellers pushing panels that were not as big as they stated. The kit I bought was advertised as “240w folding solar panel kit”. When I enquired for spec, I deduced that it was more like 160w (I have 120 watt bp units on the boat, so I know how big they should be) – still really cheap so I got it: testing as per Aus standards puts the kit at 170w, so I call it pair of 80 watt panels. So beware of the cheap panels.
