Results 1 to 3 of 3
Thread: Passenger door lock
    rockyrangie Guest
    Passenger door lock
    Hi Guys , need some help , every time i lock the doors in the P38 , everything works as normal.
    However when i unlock the doors the passenger door reads on the display as being ajar, so before moving off the door has to be opened and closed before you drive off.
    the door is NOT ajar but the system is reading it as ajar.
    help to fix this would be great .
    wayne
    zhoey Guest
    Quote Originally Posted by rockyrangie View Post
    wayne
    IIRC it's a door actuator problem and that you could bodge it by cutting one of the wires but cannot remember which. Perhaps someone else can point you in the right direction.
