                                                1st March 2012, 01:22 PM
			Puma Corrosion Protection
					Having a look at the Puma workshop manual from this thread:
 http://www.aulro.com/afvb/90-110-130...op-manual.html
 Page 1166 states:
 CORROSION PROTECTION
 The following information details the materials that are applied during manufacture for corrosion protection.
 Factory Treatments
 The Defender is treated with the following anti-corrosion materials in production:
 - A PVC based underbody sealer material which is sprayed onto the underfloor, wheel arches and undersill areas.
 - An application of cavity wax which is sprayed into enclosed cavities and box sections.
 - A final coating of underbody wax to cover the complete underfloor including components but excluding brake discs, exhaust system and propeller shafts.
 - A coat of protective lacquer applied to the whole body.
 - A coat of protective wax applied to the engine bay and wheel arch areas.
 In addition to the above measures, all steel parts are zinc-coated both sides
 I was under the impression that nothing is applied to the puma and didn't think the body was galvanised?
 Maybe this manual if referencing Land Rovers past activities.
 Any info / conformation would be great.
