Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: crashes
    May 2003
    On The Road
    crashes
    I have had a series of hard reset crashes lately when the PC has been left to idle for extended periods, 1-3 hours. I reloaded vista64 on the 28th and have over 4 thousand alerts/errors since.
    heres a pic of the last day,,
    Feb 2012
    I'd be looking at your PSU. Run chkdsk on your hdd.
    May 2003
    On The Road
    The last time "it" crashed I didnt even realise it as the screen was blank so just pushed the start button,, the PC tried to RESUME WINDOWS, [ I dont use sleep] then had a hemorrhage and did a chkdsk then fired up OK,,
    The power options are ALL set to never turn off,
    Firefox has a known problem with extended idling, which is why I am using Waterfox atm,,
    any other tests I can run?
    May 2003
    On The Road
    The PSU is new, [maybe a month old] and is 1500w's [yes thats fifteen with two zeros].
    it took 14 different swear words, 3 podge bars and a tube of lube to fit it inside the case,, I REALLY dont want to take it out
    May 2002
    Heathcote (in "The Shire")
    How well do the crashes starting, line up with fitting the new PSU ??
    Martyn
    May 2003
    On The Road
    not at all,,
    predates hardware update.
    Perth, WA
    Hi Pedro,
    I've found "WhoCrashed" helpful to pin down whats causing crashes.
    Resplendence Software - Free Downloads
    Might be worth a go.
    Tim
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    what hardware monitoring / inventorying software you go installed?
    what AV / anti malware software(s) you got installed?
    any registry tools installed?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    Avira and Malwarebytes,
    nix on the rest,,
    May 2003
    On The Road
    I tried that Tim,,
    but it seems to be focussed on BSOD's??
