Results 1 to 6 of 6
Thread: D2 TD5 2001 - slow starting
    Nov 2007
    On the road.
    hi all.
    your thoughts please, turning key over starter is engaging but car does not fire, after 3-4th try it comes to life. not happening everytime though.
    so what could be causing it?.
    battery seems ok, car has been offroad for 3 weeks prior but i put on charge overnight to give it a boost.
    appreciate any advice.
    in the wild New England, NSW
    oops ... wrong thread
    Feb 2012
    Mundaring, WA
    Doesn't sound like a battery issue if the engine is turning over. County sounds like he is on the right track. Frustrating when these problems occur intermittantly only. Good Luck
    Stumpy
    NSW SW Slopes
    Could be a failed fuel pump that is producing very low pressure or oil in the ecu harness upsetting the crankshaft position sensor.
    Australia
    Air in the fuel line. Either a filter or line problem.
    Nov 2007
    On the road.
    thanks guys, i am leading towards air in the line, will do a purge process soon to check that theory.
    car has been in the repairers for the past three weeks and they may have moved the filter/fuel piping as part of the fix which maybe caused the issue.
