Thread: tdi200 defender wading plugs?
    joetdi Guest
    g'day guys does any one know the size of the wading plugs in a tdi200 defender? and how important is it to use them? cheers
    Somewhere else, QLD
    Keeping the clutch and timing belt assembly clean & dry is very important. Imagine if you get grunge in the timing belt. Technically the thread on the plug is 1/4 BSPT, but M14 fine thread also fits (like 9/16 & 14mm spanners).
    Part number FF0 01273 ( Same for both 200/300 tdi ). See the attached picture. Probably better to buy them ( they're cheap) as they are a flanged head.
    joetdi Guest
    Thanks heaps mate
    Queensland
    Thats interesting. I understood all the threads on those engines were metric.
    NSW far north coast
    Quote Originally Posted by 123rover50 View Post
    Nope,the wading plugs are definitely BSP taper, although I don't think mine have a shoulder, just straight taper plugs with a square drive ?
    Apr 2010
    Connolly, WA
    Rick,
    The only ones I ever received with the car were similar to the ones you described (Africa Specification 300Tdi). I bought ones from Land Rover UK over the last 5 odd years that looked like the ones in the picture.
    Does a Puma have or require wading plugs?
    joetdi Guest
    got some today they are the same as the one in the photo in this thread!
