I recently managed to pull off a rear door card with the door closed, but the bottom rear corner on the front is going to be the main problem. Are you able to lever the top rear corner off enough to get your hand down in there to pop the mechanism? You'll of course need to remove the lock button surround (Escutcheon Sill). I find using a large flat blade screwdriver to pry the card off helps preserve the crumby clips a little. Work your way along to get as close as possible to the clip that you're trying to pop. Have you seen inside your doors before Vlad? Do you still have the plastic dust sheet?
James.
