D3/RRS Air Compressor
					After jacking my car on the air compressor I am now in the process of putting in a new mounting bracket.  However the top and bottom mountings on the actual air compressor are also bent and I need to straighten them out.  To do this I will have to disconnect the air compressor from the wiring harness and the three pipes.
I have the workshop manual and it just says remove the three air pipes but does say how to actually do it.
The front pipe is no issue as I just undid the brass union but the rear two I am not sure about.  The look as if they just prise out (the metal bits) of the air compressor but I do not want to do this in case it is wrong and I damage something.
So advice on how to remove the rear two pipes would be appreciated.
Also there is a large pipe (about 1.5cm across) that ends at the top of the air compressor but is not connected to it - seems to come from the rear of the car - any ideas what it is?
