Results 1 to 10 of 23
Thread: 300 Tdi head replacement questions
    Jan 2011
    Australia
    Hi guys,
    I am new to Land Rovers and have just picked up a Disco 1 300 Tdi. It has a blown head gasket. The car is 5 hrs from home and the easiest way to get it home is to drive it. I have been up and pulled the head, yep definitely blown gasket between 2 and 3. I ordered and received a new Turner performance head, bolts, gaskets etc. and am heading up to refit this weekend. I need to take everything i need with me as i wont be able to get much where the car is residing. I have the rave cd and have researched this site extensively. I am pretty comfortable with the spanner side of things but have a few questions.
    Are there any updates to the manual or TSB's that relate to this job that I need to know about.
    My other question relates to sealants and thread lockers. What would be the best sealant / compounds for the following
    Thermostat housing to head
    Inlet/exhaust manifold to head
    Threaded water pipe coupling in top of head
    Oil separator to head. I know this has an o-ring is this sufficient
    Glow plugs (anti seize? One of the old ones broke off in the old head!)
    Injectors - same as above
    Do the inlet/exhaust studs require any thread locking compound
    If any one has any other tips I'd love to hear them. I am looking forward to getting it all sorted and getting out to see some of the outback.
    Jarrod
    Im just a novice so take it for what you will. If by oil seperator you mean the black plastic cyclone that fits onto the rocker cover, Then I have seen both, ie from factory I believe LR just use the Oring. On my HS2.8tgv (very similar engine, same exact part), they use the O ring and also used a RTV type sealant, similar to ultra blue, blue maxx etc.
    What head gasket did you get? I was reading here the other day that if using metal, it is best on decked blocks and heads and all surfaces must be Uber clean, not even finger prints. Bush65 also mentioned good practice of using more torque stages than the 3 or so that LR spec. Using the same bolt pattern procedure, just doing more stages to get to required settings. I believe he also mentioned that when 75% or so there, to back all bolt off in reverse order and start again. Something about the male and female threads settling better??? Might want to search that one haha I think it is in "Tank's" 300tdi cast iron head thread.
    you should either use new copper washers on the injectors and banjo bolts for fuel return, or re-anneal the old ones. Apparently you can soften them buy using a flame from a gas stove or map-gas type tourch??? havent done it myself.
    Obviously your truck is away and not ideal world. Given that it has done a head gasket, I would address a few potential issues. That is to remove the rad when you get back, have the end tanks removed and get the core checked, if ok, rod out, if not replace. I would install a new thermostat. If you are in a hotter part of Aus, you can use Tridon TT388-180. It has a crack opening temp of 82c rather than 88c. Make sure all your hoses are in good working order, get the system pressure flushed and charged with new good quality coolant. If you have a black plastic expansion bottle you may want to change it out for the latter white/opaque type. The black ones are known to split and dump coolant. Your viscous fan may be buggered also. Check and replace accordingly....
    like I said just a novice but hope it helps some.
    Quote Originally Posted by jarrods View Post
    Hi guys,
    Thermostat housing to head ATV Blue, if your not using a gasket hylomar #3 or stag if you are
    Inlet/exhaust manifold to head Dont forget to cut the exhaust gasket into sections and either hylomar or Stag on the inletgasket but you dont really need it
    Threaded water pipe coupling in top of head Loctite 567
    Oil separator to head. I know this has an o-ring is this sufficient Yep, I usually install them with a smear of oil, grease or snow white jelly, but thats normal practice anyway
    Glow plugs (anti seize? One of the old ones broke off in the old head!) Yes, coppercoat, nickle or silver based antisieze
    Injectors - same as above I use nickle based antiseize but prefer the silver stuff
    Do the inlet/exhaust studs require any thread locking compoundNOOOOO, copper coat or nickle antisieze
    Jarrod
    Dont forget to oil the threads on the head bolts and lower dont drop them in place. Cleanliness is all important get yourself a 6 pack of spray brake clean and a bag of clean white rags before you go, take a compressor and an air duster.
    a 3/8th drive socket set with adaptors will deal with most of the work you're about to do and make sure you get your torque wrench checked at the settings you're going to use prior to heading out.
    Feb 2012
    Parkdale, Melbourne
    Ha! Kudos to you. I'm writing this from a train that is taking me 4 hours to my Disco 1 300TDI after it broke down last weekend with a leaking head gasket. I also considered what you're doing - buying parts and heading back - instead I left it with a local mechanic. I've since done some research and haven't seen anything revolutionary.... Just torque bolts down using at minimum the number of stages recommended in the correct order. head almost certainly needs skimming or it will happen again.
    Then at home Make sure cooling system is top notch. I'll be installing an EGT gauge, replacing expansion tank, cleaning radiator out and maybe changing the thermostat for an 82 degree one.
    Where is your stuck? Mine's in Buchan, Vic.
    Good luck and report back!
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Jan 2011
    Australia
    Post
    Thanks heaps for the replys, lots of good info there. I've gone with the composite head gasket as the block is not getting decked. Once I get it home I intend to go right over it and replace anything that looks remotely worn. I can afford to spend a bit and still be in front as it has cost me bugger all to date. I've done this with cars in the past I find it gives me trouble free motoring for at least a couple of years plus I know where everything is at. All the hoses have been replaced this year except the 2 heater hoses and it was one of these that blew and caused the overheating ( I have new ones of these). The timing belt and fuel filters were also done this year. Hopefully this should be enough to get me home without any dramas. This car was bought from a mate who had all the above work done but the head gasket required more funds than he was prepared to commit. It means I also get to use his shed and compressor and I also get a place to sleep. Don't know if I would attempt it under different circumstances.
    Blknight, where would you get a torque wrench tested. I have a 1/2 in Kingchrome for the big stuff and I have borrowed a 3/8 Warren and Brown from my BIL who is a mechanic for the smaller stuff.
    Thanks again
    Jarrod
    I use the cal room at work...
    But you can do it with a welder, a socket, a steel bench, a ruler and a known weight.
    Crafers West South Australia
    And for a known weight all you need is an accurate measuring jug and a 5 litre water container. That's how I checked my torque wrench.
    Torres Straits
    Jarrod,
    little 300tdi tip. Passenger side of block, half way down behind dip tube there is a bolt head. This is the block drain and will let you drop the water level from deck height down.
    Will help when you are trying to clean up the deck.
    When was the t-belt done? Although not entirely necessary to do the job. In a disco ripping the radiator/IC out and timing case off gives good swinging room. Chuck a new rubber band, idler & tensioner on and know that the other 300 weak spot is covered for a while?
    S
    Jan 2011
    Australia
    Just about done. I learnt a couple of things the hard way.
    Put the bottom bolts for the thermostat housing into the head before you put the head on. I'm hoping I can get a stud into it as the bolt is sure not going to go in. A few choice words were said when I realized this after torquing the head down.
    The other thing (not quite as bad) is to put the front glow plug in (even partially) before you put the head on. Saves removing the air con compressor to get it in.
    Apart from the above it was all reasonably straight forward and went quite well. Hopefully finish it off tomorrow.
    Jarrod
    have you tried removing the timing belt cover to get to the thermostat bolt?
