Results 1 to 3 of 3
Thread: Floaters in my oil...
    Narre Warren South
    I've owned my Series 1 for a few years now.
    It's unrestored and on full rego, made it to Cooma and back, doesn't smoke or use oil, starts OK but the oil pressure light is a bit slow going off when it starts.
    Now I could have taken the easy route and changed the switch first but I'm a glutton for punishment so I dropped the sump today. I've never done this since buying it and the engine history is unknown so I saw it as a bit of a 'health check'.
    Bled the brakes first, with the help of my 10 year old son, because the fluid is getting on a bit, then got stuck into the sump removal.
    Drained off the oil, then removed the sump.
    There was nothing in the oil I drained but floating on the bit of oil left in the sump were tiny bits of cork. Seems like either a cork composite gasket is breaking down or someone has left a bit of gasket in the motor in the past. The oil pump pickup filter was about 10% clogged with pieces of cork, I don't think this was enough to make the pressure switch sluggish but I'm glad I investigated.
    As I scrubbed out the debris that builds up in the bottom of the sump there was a lot of aluminium paste but I'm not sure whether it's from the pistons fitted or whether the engine has been rebuilt in the past.
    Fitted new sump gasket & rubber seal for the rear, new oil filter, filled her up and she runs the same as before.....
    Next the switch !
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    I would of--
    Quote Originally Posted by gromit View Post
    Next the switch ! Colin
    A couple of things I would have done, fitted a oil pressure gauge and noted the difference between oil pressure at idle when cold and then hot.
    If the oil pressure is dropping off too quick, then a set of bearings would be the way to go.
    If the oil pressure is coming up too slow, then the oil pump and pickup needs to be looked at.
    I have heard of some dismal results, when people have added EP90 diff oil into the engine, the Aluminium oxide does some nasty things to the moving parts.
    Narre Warren South
    Arthur,
    I would have checked oil pressure if I had a gauge handy. I'll have to 'borrow' a gauge from work and make up a suitable connector when I get time.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
