Bushability?
Hi Charita,
Welcome to the forum.
There are a few things that can be, and have been done, to newer Range Rovers to make them more bush ready. Unfortunately the array of after market gear that is available for other models is pretty scarce for a FFRR. Some of the stuff designed for the D3/D4 e.g. bullbars will fit with modification but raises a few issues with insurance and such. There are a few members on here that have fitted them. Have a search around and you'll find a few posts here and there.
Fitting a set of rock sliders to protect the sills is always a sound policy as these vehicles are a reasonably long wheelbase and more prone to ramp over damage than, say, a 'fender 90.
If you want to be thorough there are protective covers available for most of the driveline although it is pretty well tucked up out of harms way underneath anyway.
As for the interior, no-one here in Australia seems to produce a cargo barrier. There is a full height barrier produced by LR which conforms to EU safety standards (the standard is less strick than AU but only very marginally so). IMHO if you're going to test it to it's limits under duress this difference will not really matter. It's a slightly awkward shape to fit due to needing to keep clear of the curtain airbags. This may be what deters the locals from building one. Don't know. I have the genuine LR product fitted to my 03MY.
Don't know about the 07 but in the earlier ones the little storage cubby in quarter panel of the rear drivers side (where the rear fuse box is) there is an ideal spot for a second battery. Again have a fossick around on the forum and you'll find plenty on this.
Tyres are a huge matter of personal preference. I run GG AT2s (stock size) and have had no issue with them so far.
As for taking it into the outback. I took mine out into the Finders Ranges and parts north to check out the water in Lake Eyre for about two weeks late last year. No problems experienced and an absolute dream to tour in.
There's not a huge amount of cargo space but with the cargo barrier there's enough there for a couple of weeks of touring for two people.
Hope that helps give you an insight. This could go on for pages and hours.
If you have some specific questions I and others here will be happy to respond if we can.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
