You should have done a search previously - there is a bit on this - I did it yesterday.
The attached PDF is the official way of doing it.
The way I did it yesterday is from what Ean Austral put up - fill the fuel filter with fresh diesel before installation and then cycle the ignition (runs the lift fuel pump) a few times to prime the system - I ran the ignition for 3 cycles of 20 seconds each and the car started and ran OK.
See posts 14 and 18 on the last page http://www.aulro.com/afvb/d3-d4-rrs/...ml#post1651695
Others have said you do not need to fill the fuel filter and just need to run the ignition a few more cycles to prime the system.  The system bleeds itself.
