Results 1 to 8 of 8
Thread: Would this be heavy for my 5 m tinny?
    WA
    Hay Point
    475kg might be a little heavy on the transom unless you carry a couple of 18 gallon kegs up the front to balance it. But the HP would be phenomenal
    Cheers......Brian
    1985 110 V8 County
    Jun 2010
    Fremantle
    When too much is just right
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    Kingston, Tassie, OZ.
    The weight will fade into insignificance once up on the plane....
    I guess swallowing your tongue and getting nosebleeds from the acceleration G's would also be a bit irritating
    JC
    Melrose Park NSW
    I would be more worried once you stop and go down pretty quickly by the stern
    Pretty awesome bit of kit. Just need the right hull to put it on
    Chenz
    I do not wish to be a member of any club that would have me as a member
    Former Owner of The Red Terror - 1992 Defender 200Tdi
    Edjitmobile - 2008 130 Defender
    Jul 2007
    Only three times as heavy as your current outboard give of take a few 10s of kg.
    It would not be the weight on the transom that would stuff you up. When you kick it in the guts it would probably snap you transom from the twist as it fires up and tries to lift your hull out of the water.
    Central Queensland
    would be fun to bolt a pair to the back of a No5
    Hmmm, 557BHP in a P38A......
