Results 1 to 8 of 8
Thread: 3.9 rebuild pistons 8.13 9.35
    Sep 2011
    newcastle
    when rebuilding a 3.9 low comp motor can I buy 9.35 pistons and fit them . What is the physical difference between them . Is the dish smaller . Anyone got pics of the 2 pistons ?
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    I didn't actually do a side-by-side comparison of my old 8.13s and the soon to be installed 9.35s but I imagine the only difference is the dishing. No other way it could be done because they still have to work with the same deck height. Everything is sitting in town while the machinist does my flanged liners but I should be able to give you a photo in a week or so.
    Sep 2011
    newcastle
    Quote Originally Posted by MacMan View Post
    thanks mate .
    Im about to have my block decked just to true up the surfaces and also wonder how much can be decked off the block and heads before the intake will need machining ? Probably should have another thread for this question !
    Jan 2010
    Newman WA
    Just How Far Down the Hole is the piston(s) at TDC anyway ?
    Any head decking or Block decking theoretically requires Multiplying what you took off by the Square root of 2 for a 90 degree V
    Square root of 2 = 1.414
    Therefore .040 off = .056 of inlet manifold face Distance or .028 a side.
    And while your there , if rod length is 5.660 and Deck height is 8.96 amd Piston CR is 1.94 and stroke is 2.8
    Then half the stroke 1.4 plus the rod length 5.66 plus the piston CR 1.94= 9 which is bit strange ,seeing nominal block height is supposed to be 8.96
    so that would mean its out of the hole by .040 . Ive definately got one of those numbers wrong !!!
    Anyone know the correct
    Block Height
    Piston Center line to Crown
    Stroke
    Rod Length CL
    When my engine was rebuilt, I had HC pistons fitted vice the original LC.
    DiscoVan Guest
    You can use ford 255 pistons+30thou.
    Kiwiland
    Did it make much difference (other than being rebuilt)?
    Quote Originally Posted by Dougal View Post
    Hard to say, Dougal. It had a full balance, ports matched, top-hat liners, high compression pistons, stage 2 cam, LPG injection, Haltech Interceptor, etc. Probably made a small difference.
