Results 1 to 10 of 25
Thread: Split Rims - source of?
    Aug 2010
    Help Please.....
    I am not seeking to start or reignite any religious debate about wheels and tyres, but does anyone know of a source of 16" split rims for a current Defender.
    Purchase? Import? Manufacture? Modify?
    Many thanks
    kubota front rims are the right pattern for a deefer. If you get the right model.
    Jul 2011
    Yarrawonga, Vic
    Split rim part number: BYG5324
    Otherwise get yourself 5 Toyota split rims & take to Wheel works & they will happily make some LR pattern centres
    Also I saw some on a ex army Defender in a Sydney car yard (Alexandra or Rockdale I think) , might be worth a try checking out carsales etc to see if you can spot the one & see if the Dealer will swap for some regular rims
    Never seen a Kubota split rim ?? I just sold my 2 4x4 Kubotas b1700 & L2500 one had 16 rear wheels, one had 16" front wheels both solids & neither were LR stud pattern !!
    Morry lorry rims
    The old source of split rims was 1950's Morris commercials.
    They had wheels that went onto the Land Rover stud pattern and if I remember correctly, the center hole had to be eased a little as it was too tight to go straight onto the hub.
    The first of my split rims that I got my hands on came off of a kubota, not a small one with 16 rears, an older one, bout the size of an old school fergy with 16s on the front.
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by wrinklearthur View Post
    Thats right, I remember when I was in the CCJC (Cross Country Jeep Club) in the 1980's a bloke had 16" Morris Commercial split rims on his series one !!
    hard pressed to find any nowadays I suspect, ebay.co.uk shows no results.
    Kingston, Tassie, OZ.
    i have a set of 6 from a perentie, need some blasting and coating but will get round to it soon. as they are hard to find nowadays, i would graft some disco centres onto cruiser rims i reckon, then you could pick your offset too
    Eastern wheel works willl do that job easily.
    jc
    Jul 2011
    Yarrawonga, Vic
    jc
    Only problem is the outside diameter of a defer or disco centre is more than an inch less than the inside diameter of tojo rim.
    The centre will need to be fabbed
    ah, yes that would explain why i haven't yet seen anyone do that. i thought it was due to cost etc, but a fabbed centre would probably be stronger, anyhow.
    jc
    thats not a problem, landy steelies arent located by the center, the taper on the wheel nuts does all the work, the center is just to help you get located enough to get the rim on the hub with the studs lined up near enough in the first place.
